Overclocked
Ive built a Simple 555 Timer (operating in astable mode at appr22kHz) connected to a flyback from a Monitor (A Color Tube mind you) It works, But according to articles on the web, I should be getting 20kV! It seems I am not getting enough since I cant Use a lightbulb as a plasma globe, Yet If I use 2kV at .9A, I get plasma (but then a hole gets burned into the bulb...)
VCC= 10 (Its Supposed to be 12...This maybe because I didnt load down the 5V Rail- Which I have to do in order to use Current above 1Amp) The only thing I can think of is because I am using 10V, Or I am not using a Big enough transistor (currently I am using 2 in parallel each rated at 1Amp each- And they got hot- Intrestingly when one reaches a "max" temp, the other starts to supply more current and gets hot..)
Is there anything else that could prevent me from getting to 20kV? Im thinking I should use a Transistor Astable circuit, since it seems of all the circuits I build, the load is actually getting appr 3V From the transistor (with appr 5-7V coming from the timer).
ADD- Also at one point ( i had used a small neon bulb for the load) the Flyback started making this weird high pitched noise (I was drawing arcs at the time). The timer blew afterwards, and when I replaced it, the noise went away.
