hooking up a relay??
mossy
can anybody tell me which pins on this relay do i connect a seperate voltage onto to turn on a bulb??
and what voltage would i need in the ciruit to light your standard 60W bulb??
You could connect the supply to pins 4 and 13, and connect the lamp to 8 and 9.
The lamp will illuminate when the relay is energised.
By "your standard 60w bulb" I assume that you mean the sort of thing used to light up the room in a house.
In which case you will need 240 volts.
A few cautions!
Are the relay contects rated for 240v AC, is the circuit board(?) rated for 240v AC.
Can the relay contacts handle the current ? (about 1 amp surge at switch on)?
will it actually need the full 240volts to light the 60w lamp?? my relay is only rated ro 125volts.what current will the bulb need to turn on?? not so sure what kinda circuit board to use, would veroboard do the job??
If you want the lamp to light to full brightness, yes it will.
Then it is anadequate for the job. You need a better relay.
A 60 watt lamp will take 0.25amp from a 240volt supply. But at switch-on there will be a surge which could be as much as 1 amp.
I dont know the voltage rating of Veroboard, but I would be very reluctant to put mains voltage on to it.
Better to use mains wire direct to the relay.
I would expect the surge to be considerably higher than 1A, the cold resistance of a filament lamp is quite low. Obviously, it does depend on the exact instant it's turned ON, and where in the mains cycle it happens to occur.
Always safer to wire, but veroboard is no less safe than a PCB - as long as you use it sensibly!. Just as with a PCB use wide spacing for mains voltages, with veroboard this means removing adjacent tracks - which is simple to do by tinning and heating the track excessively.
So if i get a relay to switch 240 volts @ 2amps will i need any other components between the lamp and the mains??
Just the lamp holder, the wire and the mains plug.
