Boncuk
Hi everybody,
I opened my PC today to check for dust on the components.
All five fans worked properly and that fact is visible on the front panel measuring temperatures at four locations: CPU cooler, HDD(s), RAMs, chassis and chipset.
Measuring is done using a stand-alone "Fan Master" (Super Flower, Taiwan) which controls rpm of four fans individually based on the maximum temperature.
If temperature of one sensor has raised above the factory preset value the device will change the back light of the LCD to flashing red and set off an audible alarm. (Setting of the back light can be: red, green, blue and white)
Using three wire fans rpm is displayed on the LCD.
I could hardly believe what I saw on top of the PC case. It was a spider's web just on top between the power supply and the CD/DVD recorder.
That means that is a no-wind area, but not critical at all, since cooling of the power supply is done inside the enclosure and the CD/DVD recorder gets minor cooling underneath it by excessive air over the RAMs.
Boncuk
Boncuk
