Hello,
I have seen bench psu with positive and negative voltage output.
How are these two-voltage-units built?
I reckoned it could be done in many ways. Here are some:
The two voltages come from separate coils on the transformer, and is regulated to two different voltages with separate controllers and transistors.
Another way is to regulate the voltage once for one output, and re-regulate the same current for the second voltage.
Perhaps there are other ways.
How should it be done most effectively?
Second question:
I have seen some PSU have separate green earth ground output. Is this just paralelled to the earth ground of the device? Is this dangerous if there is a fault inside the psu? And why is it useful to have earth GND output for other than mains power?
A lot of questions, I know![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!M
Second question:
Thanks!M
