JAMES IRVINE
I am currently doing a project for a dc to ac inverter for my hnd graded unit.
I must submit a calculation and was wondering if anyone can tell me if my idea has any credibility if not has anyone any ideas.
My idea is to estimate the power losses which will result from using a low pass filter to attenuate unwanted harmonics from a squarewave output to produce a sinewave.
This is the link to the circuit which I intend to use **broken link removed**
I have to achieve a 50 HZ 240v output not 230 for some odd reason and I calculate that the current through the primary will be 30A, which I have assumed means that the load impedance must be 10hm: . I dont know if this is acceptable or whether I need to use thevenims theorem to find out the circuit impedance.
I am thinking that if I calculate using thevenims theorem to find the circuit resitance, inductance and capacitance then I can determine the power losses using the various equations for complex waves like v=16 sin wt + etc.
The problem I see with that is determining the value of the peak voltage for the 3rd harmonic,5th......, I mean can I calculate that or would it have to be measured.
For the low pass filter values I have took a wild guess that they have to resonate at 50Hz which I guess means I use a value of j35 to substitute into equations for XL and XC, I'm unsure if the resistance of the load must be taken into
consideration or whether I am miles away from the correct theory on this.
After all I know that resistance will have a damping effect and may mean that resonance would occur at different value of L and C.
