JAMES IRVINE
I am building a dc to ac inverter for a project for a diploma I am using this design **broken link removed** I have two problems number 1 the 2.2uF capacitor I have been given does not resemble the part in the project. It is huge 10 holes on a vera board long and is rated at 100 volts, can anyone tell me will it make any difference to the operation of the circuit as the 2.2uf cap determines frequency amongst other things.
The other problem is, right I've worked out that the four mosfets and the transformer will be located elsewhere other thsan on the same vera board as the controller.
That leaves me not knowing where to begin with that and also not knowing just how these two mosfets are going to be connected to make this complimentary mosfet configuration work.
Any help would be greatly appreciated.
