Hi, I'm new at this, so please bear with me. I am trying to rig up a timer that is triggered by a spdt switch. I am literally using a stopwatch, but the same button both starts and stops the stopwatch. It seems like if I was able to delay the signal on the NC side of the switch by about .5 seconds, this would work as needed because the switch is instantaneous and the stopwatch doesn't recognize that the circuit was broken, but will with a brief delay. But I can't find a delay relay that will run off only a few volts and are too pricey for what I'm doing here. right now I am using 2 switches that are physically offset to simulate this delay and it works, but it is subject to the speed at which the switches are pressed and is only about 90% reliable. Can anyone tell me if there is a way to briefly delay the output voltage of the NC side of the switch with some other type of electronic component? i would think that a resistor and capacitor could do this, but i really have no clue. thanks.
