paul.1911
I've read in forums that max i can get a 5 Amp from my alternator (i don't know how it has been tested). The stock Headlight bulb is 35W, I want to change that to 60W
It has 3 poles...one for ignition coil another two for charing battery and lightning up the bulb on AC.
Many people think that it is not possible without rewinding the coil (I agree).
Some have re-winded and 60W bulb working fine as i've read, but i have seen one guy re-winded his coil (shown in the forums with pictures) and got fail. He uses 20G wire as 19G is recommended (i dont know why)...u need a bigger magnet to get more power, don't do anything stay on the stock, he said.
Then i dont know how some peoples got working...
Impact on the Engine
also people say it'll have minor impact on ur engine that is so so negligible that u cant even recognize...on the other hand, some says u will loose ur pick up, as the load will increase and will start knocking on the upward direction....
I don't know who is correct....they are talking about the same displacement of engine.
What are ur opinions??
Is do it yourself is the only way for me?
The wire for battery from alternator have 5V more than lightning wire.
and i've got 35v at the speed of 70Km/h and 15v@20Km/h on battery line, reduce 5 for lightning wire.
I this really not possible?
I've also created my own regulator but haven't tested yet.
but let me tell u, ones i've tested a 55W bulb without any regulator and it was glowing pretty good, but haven't tested the ampere drawn by it.
I'll burn up my coil if i overload it ....and i don't want that
