I used a function generator to supply 5V ac to an op amp(Ua741) to amplify this signal to around 30 V (Dc power supply) However when i measure the output after the op amp, I got around 50 V. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I then connect this output to the piezo disc and there will be a buzz sound due to input frequency being around 13 Khz. However the res freq of the piezo disc is 2.7Mhz. During this time, I cant feel the piezo disc vibrating when i touch the piezo disc![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If i supply 2.7Mhz, I would not be able to hear the buzz sound and the piezo disc will also not vibrate. Maybe this is because i need a higher voltage to make it vibrate...
Anyone can help me find a solution to make the piezo disc visibly vibrate? Thanks for everything![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
