How can i use internal eeprom of atmega 8
arkani
Hello
i want to use internal eeprom of atmega8 microcontroller but i dont know how use it .
I use basic compailer ( bascom avr)
Any one can hellp me?
WRITEEEPROM
Top Previous Next
Action
Write a variables content to the DATA EEPROM.
Syntax
WRITEEEPROM var , address
Remarks
var
The name of the variable that must be stored
address
The address in the EEPROM where the variable must be stored.
A new option is that you can provide a label name for the address. See example 2.
This statement is provided for compatibility with BASCOM-8051.
You can also use :
Dim V as Eram Byte 'store in EEPROM
Dim B As Byte 'normal variable
B = 10
V = B 'store variable in EEPROM
When you use the assignment version, the data types must be the same!
According to a data sheet from ATMEL, the first location in the EEPROM with address 0, can be overwritten during a reset. It is advised not to use this location.
For security, register R23 is set to a magic value before the data is written to the EEPROM.
All interrupts are disabled while the EEPROM data is written. Interrupts are enabled automatic when the data is written.
It is advised to use the Brownout circuit that is available on most AVR processors. This will prevent that data is written to the EEPROM when the voltage drops under the specified level.
When data is written to the EEPROM, all interrupts are disabled, and after the EEPROM has been written, the interrupts are re-enabled.
See also
READEEPROM
ASM
NONE
Example
'name : eeprom2.bas
'copyright : (c) 1995-2005, MCS Electronics
'purpose : shows how to use labels with READEEPROM
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
$regfile = "m48def.dat" ' specify the used micro
$crystal = 4000000 ' used crystal frequency
$baud = 19200 ' use baud rate
$hwstack = 32 ' default use 32 for the hardware stack
$swstack = 10 ' default use 10 for the SW stack
$framesize = 40 ' default use 40 for the frame space
'first dimension a variable
Dim B As Byte
Dim Yes As String * 1
'Usage for readeeprom and writeeprom :
'readeeprom var, address
'A new option is to use a label for the address of the data
'Since this data is in an external file and not in the code the eeprom data
'should be specified first. This in contrast with the normal DATA lines which must
'be placed at the end of your program!!
'first tell the compiler that we are using EEPROM to store the DATA
$eeprom
'the generated EEP file is a binary file.
'Use $EEPROMHEX to create an Intel Hex file usable with AVR Studio.
'$eepromhex
'specify a label
Label1:
Data 1 , 2 , 3 , 4 , 5
Label2:
Data 10 , 20 , 30 , 40 , 50
'Switch back to normal data lines in case they are used
$data
'All the code above does not generate real object code
'It only creates a file with the EEP extension
'Use the new label option
Readeeprom B , Label1
Print B 'prints 1
'Succesive reads will read the next value
'But the first time the label must be specified so the start is known
Readeeprom B
Print B 'prints 2
Readeeprom B , Label2
Print B 'prints 10
Readeeprom B
Print B 'prints 20
'And it works for writing too :
'but since the programming can interfere we add a stop here
Input "Ready?" , Yes
B = 100
Writeeeprom B , Label1
B = 101
Writeeeprom B
'read it back
Print B 'prints 1
Readeeprom B
Print B 'prints 2
End
