Ok UK domestic freezer, I dont know much about refrigeration in general. The question is if I disabled the thermostat and replaced with something else, and maybe if I looked at better cooling for the hot side, what is the realistic temp I could get a domestic freezer down to? I am aware life span of compressor etc would be shorter and thats ok.
Type of freezer is a fairly large free standing fridge freezer, freezer section is separate from fridge and fairly large. I can cut bits of it up and that as its in my lab. It has two plates in the freezer section with pipes going through them, these are the plates that get cold. So one idea is to move one nearer the other and heavily insulted the an area, basically aiming to make the space inside to cool alot smaller than now.
My reasoning being, the compressor handles the size of space to cool to -22 at present, perfectly well, so if I decrease the area to cool then the compressor dosnt have to work so hard. With a smaller space to cool I get a tiny amount of leverage on how cool it will go down too with the compressor on for the normal time (thermostat removed obviously).
If I cool the hot side better this should also help should it not??
What else can I do without major **** like re gassing? And while i have no idea what the refrigerant inside is, it must have a limit on what it would cool too. So has anyone played with freezers? And realistically how much past -22 can i get a freezer to go down too? In a ideal world -32 - 38C would make me happy .
I havnt touched the thermostat yet, but moving it as far as it will go gets me down too -24C.
