fouadalnoor
Hi guys,
I am currently trying to create a very simple MP3 player using the VS1011 MP3 Decoder and the PIC16LF877 Microcontroller as well as an SD card adaptor.
When using the PIC as a master and the VS1011 as a slave I need to use "SCI" in order to set up various registers so that the VS1011 is in the correct mode, has the correct volume etc. I also need to send the music data through the "SPI" interface.
My question is, how do I tell the VS1011 to change interface so that it knows I am using SCI or SDI?
By looking at the data sheet (page 1) we see the pins used to communicate:
DREQ (output)
SO (Output)
SI (input)
SCLK (input)
XCS (input)
XDCS (input)
I think I understand what all pins do other than the XDCS pin. Is this the pin that I have to set high in order to communicate using SDI? (in New Mode) as shown on page 16? (assuming that SM_SDISHARE = 0)
The VS1011 data sheet is found here: https://www.vlsi.fi/en/products/vs1011.html
DREQ (output)
SO (Output)
SI (input)
SCLK (input)
XCS (input)
XDCS (input)
