A simple resistor in line with a capacitor to ground (a passive low pass filter) will completely eliminate the contact bounce effect, and also serve to limit the speed with which the buttons can be pressed (to a human level)
Use larger values of capacitors and resistor to increase the R/C time constant, which makes you have to press the button for longer ...
