how do I power a 12v fan from 220v without a transformer ?
buju357
how do I power a 12v fan from 220v , I want to use a 12v fan on 220v , doesn't matter if the 220v is ac , it will just run a bit slower.....oh , and I dont want to use a transformer.
1. You don't mention if the fan is AC or DC motor fan?
2. You don't mention the current draw of the fan?
Generally speaking, you don't safely and easily run a 12 VDC fan off 220 VAC mains.
Ron
Not very long before the smoke comes out. :)
Sell the 12v fan and use the money to buy a 220v fan.
This is probably not practical, but if you wanted to do this for academic purposes to prove that it could be done without a transformer, you could rectify the 220V AC and then use a zener diode to regulate approx. 12V for the fan, if you could find a zener diode that doesn't mind the high voltage.
A) Buy 17 1/3 more fans and wire them in series
B) Buy a big dropping resistor
3) Make a reactance divider with a big capacitor
4) Make a triac speed controller
It kinda does matter... if it's AC there's different methods for getting your 12VDC out than if it's DC...
You also didn't mention the fan rating - so assuming a PC 12V/400mA fan. If it's larger, then you should consider using a SMPS (yes, with a transformer) for a usual converter.
For AC:
One way is to extract power from the input signal while it is <12V, i.e. (assuming sinewave) between +/-2.2 degress and 180+/-2.2 degrees of each cycle.
For DC:
you can use a buck converter. You'll obviously need a high voltage output switch.
A highly dangerous way is to use a non-polarised electrolytic and bridge.
