My **broken link removed** stopped working. It blinks white (and then black) when plugged in, regardless of which type of which input plug I use. I know the monitor is the problem because my other monitor, which is the same make & model, works perfectly fine with the same inputs (knock on wood).
I took it apart and did not find any bulging capacitors.
Looking at **broken link removed**, which should I replace and where can I get it?
