How do I work with the ADC and DAC of the teensy 3.2/3.6
Sashvat
Hi guys, I am a beginner in Arduino and made a small code for a project. The project is as you turn the pot, the frequency given out on the speaker outputs a range of frequencies from 0-9000 Hz. It works on my Arduino Mega, but not on my teensy. I understand that the mega/UNO has a ADC resolution of 0-1023. For the teensy its ADC resolution is 0-65535, and DAC resolution is 0-4095, but am I using it right with my 100K potentiometer? (also would like to know how to choose a pot for these applications)
As I turn the pot, it works, but when I hit the ends, it starts behaving weirdly, I assume its the problem with my pot but didn't want to jump to conclusions. And soon I will be making my own electret microphone amplifier circuit and attaching it to the teensy. I used the teensy because it has a very high ADC and DAC sampling resolution. Let me know if this is fine. Thank you.
  • Speaker.ino
Try changing the line
Frequency = (9000.0/4095.0)*potValue; //Formula to convert analog input value into frequency to drive the speaker
to
Frequency = (9000.0/65536.0)*potValue; //Formula to convert analog input value into frequency to drive the speaker
to
Thanks, now it works, but the pot when turned to the extremes makes some weird noises and is not increasing or decreasing what should I do for that?
Print the frequency and see what it is when it sounds weird.
Edit, it probably sounds weird when you approach zero.
Also, try changing to,
Frequency = (8950.0/65536.0)*potValue+49; //Formula to convert analog input value into frequency to drive the speaker
Thanks a lot for your help, it works, I haven't tried this out "Frequency = (8950.0/65536.0)*potValue+49; //Formula to convert analog input value into frequency to drive the speaker"
it works decently, but I have bought some good potentiometers and are coming
The change to,
is so the frequency is between 50 and 9000Hz. Low frequencies can sound very strange and sometimes like clicking.
