I am designing an EMI filter to keep smart meter SMPS noise out of my house wiring, which requires coils wound from very stiff 1 guage wire. I can only get it down to about 2" in diameter, and toroid cores with that cross section pretty much don't exist. I may have to use a core that does not fill the coil.
My question is, does the inductance of a toroid change if the coil is wound larger than just fitting over the core? I'm going nuts searching inductor design docs, all of which seem to assume that the coil fits the core tightly. Is the inductance what is expected given the core's Al factor (inductance per turn squared), or less because it does not intersect the entire coil cross section?
