How I should configure a parallel port to read data?
najeeb
Does any one can tell me how i should configure the parallel port for reading data from a circuit?
I got a lot of information from the internet, but now confused by this after testing with different computer ports. I found some ports are working very well but not all. I want a unique method so that my circuit will have the compatibility with all computers, like the scanners where we are just plugging the device to any system and installing the driver sotware.
So any one can help me in this regard please do it.
Najeeb
Najeeb
If you want maximum compatibility you will need to use a standard parallel port - this only has a very limited number of input pins. So like the old LapLink software you will need to transfer data as 4 bit 'nibbles'.
There are 2 main things to check when trying to access a parallel port.
1. If PC shows it as ECP type, you must configure ECP extended control register for the proper operation mode. PortBaseAddress +&H402 (bits 5-7)
2. You must also set the direction control bit in the Port control register at PortBaseAddress +&H2 (bit 5)
To get full info go to BeyondLogic.org and download their tutorials on parallel port (all Modes). This will explain a lot of things.
Dialtone
