How set PWM for PIC 16F877A
Rooney_04
hi
how i could set this PWM for 20MHz in the PIC 16F877A? if i could get the source code should be better since i m new to PIC programming
Stop hijacking existing threads! It's not our policy to give all the answers for problems, instead we provide advice so you may think down the right path. I already presented a frequency function, why don't you use it to make a PWM function? Did you even read anything about duty cycle and PWM like I advised?
I already explained the driving frequency in the other thread, did you read about it?
PWM Function
Here's a PWM function I just did using C18 with the PIC18F1320. You should be able to translate it to the PIC you want to use. If you can't even do that, you better learn some simpler projects to program first.
    void pwm(char pins, unsigned int duty, unsigned int freq, unsigned int timer)   // PWM Function
            unsigned int times, on, off;
            TRISA = ~(pins & 0xFF);
            on = (65536 - duty);
            off = (65536 - freq) - on;
            INTCONbits.TMR0IF = 0;   // Clear OVF Flag
            LATA = pins;   // Initialize LATA
            T0CON|=0x80;
            for(times=timer;times>0;times--)   // Duration of playing
                if(freq<=duty)
                    LATA = pins;
                else
                     TMR0H = (on >> 8) & 0xFF;   //Load TMR0H byte first
                    TMR0L = on & 0xFF;   // Load TMR0L byte next
                    while(!INTCONbits.TMR0IF);   // Wait for timer
                    LATA = ~LATA;   // Invert output
                    TMR0H = (off >> 8) & 0xFF;
                    TMR0L = off & 0xFF;
                    LATA = ~LATA;
