Ryan Birkenholz
Hi, I am trying to repair my Onkyo HT-R520 stereo/receiver. The problem is that one or more channels sometimes cuts out. If I tap on the case I can sometimes get it to come back. I took it apart and there are a series of 3 ribbon cables with bare wires connected to a circuit board via this white connecter (see photo below); if you can't see the photo, it is one of those white connectors soldered to the board where bare wires are inserted and metal tabs hold the wires in place, then you put a plastic cap over them to secure it. I am almost positive the problem I am experiencing is because I am not getting a good enough connection through these connectors. I tried to carefully bend the metal tabs back a bit to provide more pressure, but it still isn't working. I was thinking that maybe I would just buy a different style of connector (perhaps a more secure plug-style). What would you suggest to fix this? I can't solder the wires directly to the board because I can't access the solder joints unless I disassemble it, and disassembly would be impossible without removing the wire.
here is link to the photo:
http://www.ryanbirkenholz.com/images/PCBconn.jpg
![PCBconn.jpg](https://www.ryanbirkenholz.com/images/PCBconn.jpg)
