How To Add Nicely Aligned Code
Gayan Soyza
Active Member
Evertime when I add my assembly code it will uploading with messed up.How do you upload nicely aligned code?
Do_UP            movlw        .10
            movwf        Hold_Time
            incf        Character,F
            movf        Character,W
            xorlw        .94
            btfss        STATUS,Z
            goto        Do_UP_Select
            clrf        Character
Do_UP_Select        movf        Character,W
            call        Load_Char
            call        Adjust_FSR
Do_Check_Up_Rel        btfsc        PORTB,4
            goto        Text_Key_Check
            btfss        Flag_Register,End_Frame
            goto        $-1
            bcf        Flag_Register,End_Frame
            decfsz        Hold_Time,F
            goto        Do_Check_Up_Rel
            goto        Do_UP
I copy the code into notepad++ before posting here,
Do_UP           movlw   .10
                movwf   Hold_Time
                incf    Character,F
                movf    Character,W
                xorlw   .94
                btfss   STATUS,Z
                goto    Do_UP_Select
                clrf    Character
                call    Load_Char
                call    Adjust_FSR
                goto    Text_Key_Check
                goto    $-1
                decfsz  Hold_Time,F
                goto    Do_UP
I think it's set to convert tabs to spaces which is why it works.
But, every now and then it still messes up.
Can one of the site technical guys tell me what font the code box uses? Maybe setting Notepad++ to the same font will fix it.
I believe it's Consolas.
Hi Mike,
I downloaded and installed notepad++. I did your method & it worked nicely.
Thanks.
Sec_Adj_Mode    bcf        PORTA,7           ; CS/ = 0
                movlw      .8                ; digit H10 blank
                call       SPI_Out
                movlw      b'00001111'
                call       SPI_Out
                bsf        PORTA,7           ; CS/ = 1
                movlw      .7                ; digit H1 blank
                call       SPI_Out
                movlw      b'00001111'
                call       SPI_Out
                bsf        PORTA,7
                movlw      .6                ; digit M10 blank
                call       SPI_Out
                movlw      b'00001111'
                call       SPI_Out
                movlw      .5                ; digit M1 blank
                call       SPI_Out
                movlw      b'00001111'
                call       SPI_Out
