EPS Bench setup we are thinking about: Torque Angle Sensor (TAS) will be emulated by PIC microcontroller. Emulated TAS will be connected to EPS ECU's Single Edge Nibble Transmission (SENT) bus.
Our strategy in getting started with EPS Bench testing: Use PIC microcontroller to apply different inputs to the ECU. Motor connected to EPS ECU will be controlled by PWM output.
We need to measure the output. What parameter(s) do we measure? current, voltage, PWM duty cycle, PWM frequency?
If the only bench equipment we are planning is PIC microcontroller to emulate TAS, EPS ECU, power supply, Vector CANoe and CANape, do we need a load at the output? For example, do we need a motor or some load like inductive load.
Our goal is to verify that software is correctly processing inputs by measuring output?
If we need a load, what load should it be? What parameter(s) do we measure? And where should we measure?
If we don't need a load, what parameter(s) should we measure? And where should we measure?
