I have 3 pulse jet engines that I designed and built using German V1 flying bomb research data. They starts easy and runs great. I need to determine the number of pulses per second that each engine fires and the exact thrust the engine produces. I have not tried anything yet to test the pulse rate of frequency but it should be very close to 400 pulse per second. I used a spring to test the thrust the amound of movement on the spring gives me a fairly close guess within 90% but it is not accurate. I want to run the engine on different fuels and different fuel mixtures so I need something very accurate to measure thrust in ounces or smaller. I also need to determine the velocity of the1500 deg F exhaust gas this will tell me how fast the engine will fly on a model airplane the speeds should be some where from 100 mph to slightly less than 300 mph. I was thinking a strain guage might work for testing the thrust.
Check out the video.
YouTube - Lowracerman's Channel
