How to configure STM32 timer for LED flashing
jab99407
Hi.. I want to blink an led using a timer interrupt.
I open Device Configuration Tool
Next, I go to PD12 pin and select TIM4_CH1 option.
Now I go TIM4 timer mode and configuration
Clock Source: Internal Clock
What timer configuration are required to flash LED for 1 seconds or What timer configuration are required to generate 1ms timer interrupt ?
Why are you using a 32 bit processor to flash an LED? You seem to have the starting objective, flash an LED, on a Formula 1 microprocessor.
I suggest you start somewhere simpler.
I don't think there is anything simpler than LED. I wrote LED blinking code using software delay. Now just want to generate timer interrupt for 1ms I would toggle LED when I would count 1000 interrupt for 1 seconds. That's why I want to configure to generate 1ms. I don't understand which option should be select for 1ms in timer mode
Starting on such a powerful processor is not necessary unless your intention is to learn that particular processor, however learning a simpler one first would be advised. If your intention is to learn to program then I suggest starting with something like an Arduino Nano.
I have knowledge of PIC microcontroller and I want to learn ARM processor.
I assumed one of two reasons - either this is part of a bigger project or you're learning to use ARM.
It's never helpful for someone to raise objections to your project or question your aims without knowing why you're doing it. The only way to stop people doing that is to say clearly when raising the question that you are doing this while learning to use this processor. Then you may get some helpful responses.
I'm afraid I can't help you either, I just don't like to see someone possibly discouraged by having their query trampled on without helping.
I assume you're referring to me as I'm the only person to respond, except for your negativity. I stated my view and added a "unless" which turned out to be the case. Well done on bringing this to a useless end.
