How to convert C -> Asm -> Hex {pic}
You convert C -> Hex and Asm -> hex, but you don't go from C -> asm.
They both require compilers for the specific chip you are working with.
I have just learned how to get c into asm/hex and tehn onto pic. I used a program called mikroC and its quite easy to use.
Hey Smanches, don't let 3v0 see that!
C needs to be compiled into ASM, then assembled into HEx, you can do this use all kinds of software compilers, including MPLAB.
ASM is assembled into a HEX file as stated above.
Turning C into ASM is an intermediate step.
But there is nothing the user has to do to compile the intermediate ASM. It is not a human involved step, so it's moot to point it out to the OP.
i cont understans C .so i want C convert in asm. i have some C , project
for modi. can any body convert it for me ?
  • main.c
Microchip's MPLAB can read a PIC and display its output as assembler.
The PIC is loaded into the programmer and read. The resulting file can be seen by using the "View" pull down menu and "Program Memory." At the bottom of the display click on "Machine," or "Symbolic" to see the ASM.
I haven't tried doing this with a Hex file, but should also be possible.
