A couple years ago I sent a bunch of pcb designs to iTead for cheap PCB and making them open source, I got 2 more for each order of 10 plus a few extra PCB from other open source projects. I got quite a few "iTeaduino" board that have been put aside but I would like to put it together.
**broken link removed** has the schematic and pictures of the board but I can't find part list with the size of SMD. So is there a way to find out what physical size SMD are used? I thought most capacitors and resistors are 0805? The only thing I have for measuring small area is a dial caliper that has imperial (English) measurement, no metric. Even then, measuring the pad I have is not quite accurate as the actual SMD is usually slightly smaller than the pads.
