I've finally got a 16F877 generating a command, as per the SIRC protocol (Sony IR command) with (1- start + 7- command + 5- device) pulses and just for testing, the signal is emitted through a continuous loop.
I've spent quite some time trying to freeze the trace in my scope to actually count the pulses and measure periods but to no avail. I can frezze two or three pulses but if I see the whole "packet" I can't count / measure anything. :cry:
My scope, far from a DSO is a imple analogic 10 MHz dual channel. What's the simplest setup to be able to get a steady image on the screen? Any trick I could play to be able to explore the packet along the full length :?:
While typing this I realized that a certain instability is due to a TMR0 interrupt providing a time base for other purposes. I forgot to disable it and will be the first thing to do tomorrow at the bench.
Suggestions / comments appreciated :!:
