How to I build a rectifier for a stepper motor??
raptorpilot03
Ok similar to a few other threads, I would like to convert the output from a brushless stepper motor into pure DC. I have heard it is quite possible and even simple, however have been unable to find a way.
It is a small Remote Control motor, which I wish to convert into a small wind turbine, but first would like to gauge the power output, and cannot seem to get any measurements for it.
It can be found here:
It has 3 wires, black red, and blue coming out, and I was wondering how I go about inserting this into a circuit, and hence a multimeter to get a few readings.
Thanks guys
Just like an alternator except permanent magnets instead of a field winding.
Can anyone be a little more specific, I was hoping to make it a little smaller and not use an old car alternator.
I heard u can components on a small breadboard and run it through that.
Thanks though ronv
Its the same as an alternator.
How much current can your motor handle?
You dont use one you wire your motor like one.
You dont need a breadboard, its only 6 diodes. use a term strip.
Andy
This is a link to your motor's instructions. You would configure it like the attached image. You can either use a 3 phase rectifier pack or use discreet diodes. Just make sure you use diodes rated for the application. The image does not include capacitors for filtering! You will need capacitors across the DC out.
Ron
