I have a bunch of pcbs I made for a simple audio mixing circuit. The audio is fed into 10k pot acting as an attenuator and then summed with an opamp summing circuit (where the summing resistors are 4.7k).
This circuit works perfectly.
However, I ran out of 10K pots and I had to use 100K instead. This creates an exaggerated response curve.
I tried the simple trick of putting a 10k resistor across terminals 1 and 3 of the 100k potentiometer. This resulted in a response much closer tot he 10k pot BUT there is a huge jump at the last few degrees of the rotation.
I guess it is making a kind of s-curve response.
Is there an easy way to fix this or a better way to make a 100k pot perform exactly like a 10K?
