Fourcorners
Hoping someone can help me with this issue. I have two cats and I purchased a "Cat Furniture" litter box for them. It will be placed in the garage with a pet door from the house leading to it. I want to pull the litter box air out of the furniture box and vent it to the garage. I bought two Nexus fans per the following specs:
Nexus Real Silent 120 mm Case Fan Specifications
Model D12SL-12
Power Connector 4-pin & 3-pin
Dimensions 120x120x25mm
Rated Voltage 12 Volts
Operation Voltage 6.5 ~ 13.8 Volts
Input Current 0.30 Amp Max
Input Power 1.8 Watts Max
Can anyone tell me what I need to do to supply power for one of them or both of them at the same time. I know I need a small ac/dc power supply but I don't know what size or type. Also; how do I hook up the power. The connectors are listed above. The fan is for a computer but I purchased it because it is very quiet. Didn't think that the cats would like to hear a lot of fan noise while they are doing their business.
Any assistance would be appreciated.
Thank you!
Model D12SL-12
Thank you!
