One motor tends to go faster than the other when connected in series.Why not just use two of those fans connected in series.
Bangladesh air is hot enough to have an extra fan.![]()
Why doesn't the OP stick shis resistor in the air stream in front of the fan. That will keep the resistor from burning up, and it will keep herm warm, too.![]()
No, that sounds wrong. 50% sounds right.Except you need a duty cycle of 25% to mimick half the voltage because the RMS voltage of a squarewave is Vpeak√duty.
