rjvh said:i don't realy know what you mean with the underside of the picture but the schematic is a simple one
Robert-Jan
chadster said:here's the schematic from the box from the relay. I need to know what numbers are where...
chadster said:Yes it does.
rjvh said:the schematic is not clear which contact nr is NC (normaly closed) or no (normaly open) can be tricky
Mickster said:IIRC, without power to the relay coil, 87a is NC (to 30) and 87 is NO. And vice-versa when powered. A quick check with an Ohm meter will verify this as I don't have any of these relays to hand.
For more information on automotive terminal designations, have a looky here:
http://www.type2.com/library/identifi/bosterm.htm
HTH.
