How to Use digitalRead in Arduino? - Technetron Electronics
lucashenry
Hi everyone,
I'm new to Arduino and trying to understand how to use the digitalRead function in my project.
I have an Arduino Uno and a simple circuit set up with a pushbutton connected to pin 7.
I'm looking to read the button state, but I'm not sure about the correct way to use digitalRead.
Can anyone explain how to set up the pinMode, how to use digitalRead to check the button's state, and any tips for troubleshooting or common mistakes?
Any help or resources would be greatly appreciated!
Hi everyone,
Can anyone explain how to set up the pinMode, how to use digitalRead to check the button's state, and any tips for troubleshooting or common mistakes in How to Use digitalRead in Arduino? - Technetron Electronics?
thanks in advance for any help
The Arduino IDE has an Examples section to show you exactly how to do that.
Also look around the Arduino site which has masses of info - below is the link to the Digital Read .
https://docs.arduino.cc/language-reference/en/functions/digital-io/digitalread/
Loads of info on the web for Arduino beginners including Ytube tutorials etc.
For testing out your switch you can use it to turn a led on or off or send suitable text to the Serial Monitor screen.
Use pinmode to set pins as input or output, by name, eg.
pinMode(PA2, OUTPUT);
pinMode(PA3, INPUT);
digital read returns 0 for low or non-zero for high. You can either use variable = digitalread...
or simpler you can simply use the result directly in a conditional statement, like
if(digitalRead(PA3)) {
// pa3 was high if this executes
digitalwrite sets the pin high or low:
digitalWrite(PA2, HIGH);
You can also give names to pins at the start of the program so you can use a name rather than a pin directly, like
#define JS_L_PB PA6
then later
if(digitalRead( JS_L_PB )) {
// left joystick switch was pressed
When you read a mechanical switch it has "electrical bounce" where the contacts, for
a short amount of time, bounce and cause alternating 0'sd and 1's at the pin.
This is handled by debounce code or additional hardware :
Regards, Dana.
