I have VMII-PLUS-5.5KW hybrid inverter. It has 220V AC IN marked as L, N and ground, see picture
In Canada, we have two 110V lines L1, L2 with reversed phase and N and ground are middle.
I plan to connect L1 to AC IN L, L2 to AC IN N and ground to inverter's ground.
Inverter makes no assumption about N being ground, I checked resistance between N and ground, there was some momentary resistance, but in few seconds went to infinity.
When running from utility power, center potential is provided by source. But when running from batteries, there is no center potential and if connected to distribution panel directly, L1 or L2 voltages would be undefined depending what appliances are connected. So I need to recreate center potential.
Is it possible to use 220/110 step down transformer to create the split potential and use it as neutral/ground like shown below ? I believe there would be high ground currents.
