Migs said:Thanks billboard, I will search for some. If I cant find some, do you think medicinal alcohol will work?
Migs
Migs
Dean did say "for the most part".Dean Huster said:...
However, remember that flux removal, for the most part, is a cosmetic thing.... I wouldn't mess with it.
Dean
Maybe you could learn to do so, but it is not required. Nor are you required to buy every tool mentioned here. What you should buy depends on the thickness of you wallet and what you are attempting.You do not need a stinkin liquid flux pen. I solder with a blowtorch and both hands tied behind my back.![]()
Migs said:The reason I ask is because I was building a Sumovore Sumo Robot kit with my son, and the instructions mentioned cleaning it off for better results.
mneary said:Corrosive fluxes are normally removed with water or IPA. It doesn't usually matter with the rest of them.
chemelec said:First, You should NEVER USE Corrosive Flux on any Circuit Board.
Secondly, Contrary to Manufacturers Claims, Most Rosin Fluxes are Somewhat Conductive.
** Especially in Sensitive Circuits and more so in a high humidity enviroment.
I Always Recommend Removing the flux on all Boards.
chemelec said:Secondly, Contrary to Manufacturers Claims, Most Rosin Fluxes are Somewhat Conductive.
