I have an addressing issue with these chips. The only address that works between encoder and decoder (that makes VT go high) is leaving all 8 address pins floating. Tried all low with dip switch, no go. The datasheet looks like it should work as long as dec and enc have same address. Do any of you use pullups on the address pins?
Thanks.
Thanks.
