Micorwave ovens have cycles that run a while then stop heating and do some sensing. On mine it is popcorn and sensor reheat.
I would guess they are sensing humidity. If this is true how do the protect the humidity sensors ?
Has anyone salvaged such a sensor. What are they using ?
why
I am building a controller for a dehydrator. I could leverage a setup I built with a Honeywell HIH-4000-001 sensor that will give me both temp and humidity. I am worried about contamination. This from the datasheet sounds promising.
why
I would expect a microwave oven to be a harsher environment then the dehydrator. So I am wondering what they are using. Do they use any protection like a filter ?the RH sensor is a laser
trimmed, thermoset polymer capacitive sensing element with
on-chip integrated signal conditioning. The sensing element's
multilayer construction provides excellent resistance to most
application hazards such as wetting, dust, dirt, oils and
common environmental chemicals.
