If you are sweating then your resistance is low then the current will be high. If the current travels through your heart (arm to arm) then it will probably kill you.
I saw a worker touch 450V and ground with one hand. He fell off the ladder and his hand was burnt. Luckily the current did not pass through his heart.
Always discharge high V caps for 1 minute due to leakage to memory effect or dual layer charge effect. If you plan on handling or getting near them. Maybe your is not big enough to fribrilate or stop the heart if strong, but can be a shocking experience.hi there
I'm very pleasure to joing here
i want to ask about Ac capacitor single phase with ratings 1.7 uf and ac 450 v
single phase
is it dangerous shock from it
what the current that will get from it
i hope to know details about that
thanks in advanced
That depends how the fan (and your house circuits in general) have been wired! Don't assume it's discharged or disconnected from Live/Phase.when someone turn off the
Ceiling Fan is the capacitor completely discharging its charge while the fan slowly stops
Welcome, Mido2115!so may i think that shock not from capacitor cause i touch the terminals out from the fan to main ac source?
"i want to learn to know"
I would say significantly better than an concrete floor since concrete contains metals.Floors in houses are often wood, and you can still get a shock through it - but probably slightly better than a concrete floor?.
