i, j, k unit vectors
PG1995
Active Member
Hi
I'm little confused about the operations on unit vectors i, j, k which are in the directions of positive x, y, z axes. My confusion is about the #2 and #3. For instance, #2 says i x j = 1 but #3 says i x j = k. What's the difference? Is #2 giving information about the magnitude and #3 about the direction? Are there some other related operations which can be included here? Please help me with it. Thanks a lot.
1: i . i = 1 ; i . j = 0 ; i . k = 0
2: i x i = 0 ; i x j = 1 ; i x k = 1
3: i x j = k ; j x k = i ; k x i = j
Regards
PG
The result of a cross product is always a vector or a zero vector. So there must be an error (typo) in the text.
- Lines 1 and 3 are correct.
- i x i = 0 is correct.
- These are incorrect: i x j = 1 ; i x k = 1
Yes something is definitely wrong with line 2. It's not even the magnitude in that last one it's totally wrong.
Hi
Regards
PG
I'm not sure what source you found this in, but I suspect the following is the intention of the author. Simply add the magnitude operator to line 2.
2: | i x i| = 0 ; | i x j| = 1 ; | i x k| = 1
Hi Steve,
Yes that's what i was thinking but then the -1 in the last result threw me a curve.
