I need an ID on a momentary push switch‏, or a Compatible replacement
danrogers
Here is a picture of the switch a work collegue of mine needs for a spectrum anayliser.
It is approx 8x8mm momentary switch, ~14.5mm height, with two PCB through hole connectors with a 10mm pitch.
A few of them appear to have had their contacts broken inside and are not functioning. Could you advise if you have seen them before or if you know of anything that would be a fitting replacement.
Regards and many thanks
Dan
