I NEED CODE FOR 8051 SERIAl comm..PLSSS HELP
kumar_3k
GUY PLS HELP ME , I NEED ASSM CODE(INTEL) FOR 8051 :TO RECEIVE DATA FROM SERIAL PORT AND SEND IT TO PORT1 AND TO READ DATA FROM PORT2 AND SEND IT SERIAL;WITH CONTINUESLY.
IF ANYONE HV THIS CODE PLS LEAVE THE CODE IN THIS PAGE...
ANY SIMILAR CODE ALSO FINE FOR ME...THANKS.
Try This:
;All baud rates @ 11.0592 MHz
.EQU	BAUD_CONST,	250		; 9600 BAUD
.EQU OLD_DATA, 0x30
.EQU NEW_DATA, 0x31
.ORG	0000H
	LJMP MAIN
.ORG	0023h		; SERIAL I/O INTERRUPT VECTOR
	LJMP UART_INTR
; PROGRAM ENTRY POINT
MAIN:
	CLR	ACC
	MOV	NEW_DATA, A
	MOV	OLD_DATA, A
	LCALL	INIT_SERIAL
MAIN_LOOP:
	MOV	NEW_DATA, P2
	MOV	A, OLD_DATA
	XRL	A, NEW_DATA
	JZ	MAIN_LOOP
	MOV	OLD_DATA, NEW_DATA      ; Send character if data is changed on P2
	MOV	SBUF, NEW_DATA
	SJMP	MAIN_LOOP
; INITIALIZE SERIAL PORT
INIT_SERIAL:
        CLR     EA
        ORL     PCON, #10000000B        ;SET DOUBLE BAUD RATE
        ANL     TMOD, #00001111B        ;CLEAR ALL TIMER1 BITS IN TMOD
        ORL     TMOD, #00100000B        ;SET TIMER1 AS 8 BIT AUTO RELOAD
        CLR     TR1                     ;MAKE SURE TIMER1 ISN'T RUNNING
        CLR     TF1
        MOV     A, #BAUD_CONST          ;256 - (CRYSTAL / (BAUD * 192))
        MOV     TH1, A                  ;SET TIMER1 RATE
        MOV     TL1, A
        MOV     SCON, #01010000B        ;CONFIG SERIAL PORT (RI AND TI CLEARED) MODE=1
        SETB    TR1                     ;START TIMER1
        SETB    ES                      ;ENABLE SERIAL PORT INTERRUPT
        SETB    EA                      ;ALSO TURN ON INTERRUPTS IN GENERAL
	SETB	PS			;SET SERIAL PORT PRIORITY LEVEL
        RET
; SERIAL PORT INTERRUPT SERVICE ROUTINE
UART_INTR:
GetChar:
	PUSH	PSW
	PUSH	ACC
	JB	TI,TRANSMIT_1
	JNB	RI,GetChar
	MOV	P1, SBUF ;Send Character to P1
	CLR	RI
	SJMP	INTR_END
TRANSMIT_1:
	CLR	TI
INTR_END:
	POP	ACC
	POP	PSW
	RETI
And remember one thing. Do not post your question twice or thrice on this forum. Crossposting will not get you faster replies - moderator @ www.electro-tech-online.com
