Yes by previous owners. I tried flipping the one labeled garage as well as a lot more, but that didn't workA breaker may not look tripped when it has – the lever may only move slightly. Are the breakers labeled?
Thank you, Thats what I did though. Im thinking maybe a connection in the outlet burnt off or was slowly wiggled off. Would that be a possibility?Some of them need to have the lever on the breaker moved all the way to the off position when resetting them. Just moving the lever to the on position from the tripped position isn't enough. Tripped and off are two distinct positions even though there isn't much lever movement involved.
My garage outlets no longer work after experiments with my variac. I have checked every breaker but none are tripped. I tried flipping and reflipping some of them to see if the outlets would start working, but nothing! I don't know what to do.
