it consists of keybad containing twelve switches,a piezo sounder,LED.and the keybad wired as shown
portB CONNECTIONS
D0 D1 D2 D3 D4 D5 D6 D7
KEY1 KEY2 KEY3 KEY4 KEY5 KEY6 KEY7 KEY8
PORTC CONNECTIONS
KEY* KEY0 KEY9 KEY# LOCKoutput alarm
i am required to produce a program that will require a user to enter a four digit code,(1 2 4 8) by using a keybad.The keybad is connected to port B of the microcontroler.if this sequence of numbers agrees with the entry code of (1 2 4 8) you must output a logic one on PORT D6.This will light the LED.in full system this output will enable the electric lock.if the code is incorrect then you must place a one on PORTC D7.this pin is connected to a piezo sounder and will indicate that the incorrect code has been entered.
NOTE:the alarm must not sound untill the 4 digits have been entered.please provide me with the (asm) file thus i am using the mplab v8.33[/B]
and your help will be apprecated.
thank youuuuu
portB CONNECTIONS
PORTC CONNECTIONS
thank youuuuu
