i need to build an intelligent charger
josi
hey guyz! what i'v uploaded is a alternator. my project is to build a prototype which will cost less but has to have the same response curve has the original. i'm really not good in electronics, but if u give me some good references i'll manage. u can find info about those alternators @ www.victronenergy.com
thanx
  • 3146_1.pdf
According to graph, it seems that the nominal charge voltage is 13.4 V. Before this voltage adjustment, electronic card should see the max. charge voltage 14.4 V. In other words, it can be said that after the card measured 14.4 V (while automobile speeds up) is voltage regulator starts and determines the charge voltage as 13.4 V.
You need a microcontroller circuit that will measure the charge voltage and turn on the regulator according the voltage.
