i need to drive stronger IGBTs
sina.vahdat
I have used HCPL316J to drive a 100A IGBT. But now i need to drive stronger IGBTs that need higher gate current that HCPL316 can't supply. Additionally I want to have short circuit protection. Can anyone help me? Does any one already have the map of a circuit of a driver that has protection? I think this is a general task and surely there is some one in this forum that has this maps and circuits.
thank you.
International Rectifier makes a whole line of Gate driver IC's (IR21xx series) designed specifically to work well with very large MosFets and IGBT devices.
put a CMOS stage on the output to increase the drive capability. That is what I do for the 600A modules I drive.
I use a HCPL3120 since it has a nice undervoltage lockout, runs from 15V but has a 2.5Amp drive capability. I need to hit some of my IGBT's with a peak of 15Amps so... buffer the output stage.
What are you driving?
I want to drive Skm200GB12T4. After that greater IGBTs for a melting furnace.
Can you please tell me the exact number of driver from that family? because I searched a lot and found that they can just supply 2A or 2.5A output current. Another problem with them is that they don't support desaturation protection.
It's a great Idea.You mean I use a buffer IC? So how can I implement negative voltage by that mean? Because using negative voltage as you know is important to avoid malfunctioning. Another question:rolleyes: How do you implement desaturation protection? Do you design that circuit yourself? And do we need to design over current protection ?(separately from desaturation protection)
