what is the best way of protecting a i/o from overvoltage? zener? Transient voltage suppression diode?
anything else u can use?
and how do you protect the io pins against reverse polarity whitout effekting the voltage that the pin reads?
i mean if you have a schottky then 0.7 volt will go over the schottky and less will arrive to the pin i guess. and then maybe you read '0' when it should be '1' at the pin. is there some way of doing this whitout effecting the i/o pin.
