I2C communication between PIC24f and PIC18F
puneetnepsam
Two microcontrollers 18f and 24f are connected through a I2C interface. i want to test that I2C interface.
18f i2c address is 1000001......
i have sended the command
send_i2c_byte(0x82)....//write mode
and then sended some data eg.
send_i2c_byte(0x02)
should i receive this data automatically to the I2C recieve register of the 18f?
thanks in advance
Puneet
If you have the settings right, after you send the address and have the last bit high (to indicate you want a receive), the PIC should have a register that will fill up with the next transmission from the slave.
i want to send a data to the pic 18f controller's eeprom
if i send the address of the pic in the write mode
i.e. 10000010 (0x82)
and then i send the data through the bus.....
can i receive that data onto the i2c receive register of pic 18f??
so that after taking the data from the register, i can put it onto my eeprom location
I've never implemented an I²C slave but I would imagine that as long as you write 0x82 to the SSPADD register of the slave then it would work as you describe. You may have to check the D/A bit in SSPSTAT to differentiate between the address and data bytes.
Be aware that writing to EEPROM is slower than I²C and so you may have to implement clock stretching.
