I2c communication usinf PIC16F876A with EEPROM(M24C64)
RedEyz
Hi im student and im stuck in using built in i2c i dont know if the header file is working properly or not can any one plz help me with this.
i am using IAR embedded Workbench v2.21
PPPv3 to burn hex file
E-Block Matrix Multimedia is being used
3.2768 Mhz Xtal
E0=E1=E2=GND
100nF Capacitor across +5v and GND
4k7 Ω 2 resistors one in SCL and one in SDA
i want to see the results on the LCD.
please tell me whats wrong with my header file i have taken it from some online and its seams to show no error in my compiler but it does not work.
  • FINAL YEAR..c
  • LCDdrive..c
  • i2c..h
When you write to a serial eeprom there is a delay whilst the write takes place and in this time the chip doesn't respond at all. To ensure the chip is responding you have to wait for an acknowledge after sending the ID (0xa0). If no ACK is received you have to send a stop and do it all again.
Assuming the library routines you are using return a boolean to signify ACK/NACK then something like this should work.
void write_ext_eeprom(unsigned short address, unsigned char data)
    i2c_start();
    while(i2c_write(0xa0)==0){	//if no ACK
	i2c_stop();		//then stop
	i2c_start();		//and restart
    i2c_write((address >> 8) & 0xFF);
    i2c_write(address & 0xFF);
    i2c_write(data);
    i2c_stop();
    del();
Check the manual of your compiler as it may return true for an NACK.
You will also need to modify the read function.
Edit, just looked at I2C.h and i2c_write does return 1 if an ACK is received.
Hi thanks pommie for reply. i have tried ur idea, now what is happening is the data is being sent its sends the acklegement that data is sent but it does not recieve it it show me 255 output please help
  • FINAL YEAR..c
  • i2c..h
