Ok i'm starting to realise that lot's of idea's i have can be easily made with the use of IC's. And it seems that a PIC Microcontroller is a popular choice.
I've looked at some PIC beginner kit's as i'm a little clueless to say the least. Can anyone point me in the right direction please.
I have some silly Q's too. Most of the circuits I want to build will be used where there is a 12v supply, can i just use a zener diode to reduce voltage to supply the IC's and circuit ?
I am only guessing at the mo that a PIC is the right choice, as i'm not sure what IC's are available and what they would do, If i give some examples of circuits i'd like to design and build perhaps someone can get me on the right track.
Servo controller:
I'd like to use a servo to control a choke operation on the carbs on my bike, although i have found a circuit using a 555 chip i wonder if there is a better way to do this ?
Temp display:
Looking at the use's of the 555 i'm wondering if i can use the temp sensor already fitted to my bike, which is just a variable resistor the changes with temp. Using the change in resistance and a 555 I could create a varying frequency signal. Could this be sent to a PIC to then light up LED's as temp rises. Also at a preset temp could i activate the servo above to work as an electronic auto choke ?
Rev counter:
Think i might be biting off more than i can chew, but maybe i could start with an LED rev counter ?
Am I gonna come across problems if all signals are not digital, i.e. sine wave rather than square wave. Ok i know i've far to many Q's but my heads doing circles now and i want to learn this stuff.................
HELP PLEASE !!!!!!!!!!!!
Thanks all
Glen
Servo controller:
Temp display:
Rev counter:
Thanks all
Glen
