Hello to all.
I'm new to the forum. And new to the PIC MC.
This forum has been a tremendous help in getting up to speed quickly on everything needed to work with PIC's. I've had previous experience with other MC's (i.e. Intel 80xx, and Motorola 68xxx), but have never done anything with PIC until now. So thanks to all the great info here, I was able to successfully design, prototype, and build my first project incorporating a PIC16F88. Having never worked with A/D before, I thought this would be a good time to learn.
As my first post, I thought I'd share something that may help others.
I've been using MPLab to do all the code, simulation, and debugging (of course).
And I chose to use an enhanced JDM serial PIC programmer from MCUMall (https://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3170). For $5.50 on eBay, I couldn't resist
However, I had been using the latest version of IC-Prog (v1.06 at the moment) running on WinXP Pro SP2. Each time I'd hit the "Programm All" button, I'd get a "Verify failed at address 0000h" error during the verification phase of the programming operation. The code actually does get into the my PIC16F88 (I know, cuz when I'd install the PIC into my target application, it work as designed)... the verification would just fail.
So I got to looking at the signal on the MCLR pin, and noticed that IC-Prog wasn't holding it high (13V) during the verification phase. On a hunch I downloaded an older version of IC-Prog (V1.05d). It works perfectly now. Sooooo, I'm thinking a bug has been introduced in V1.06. If you're having the dreaded "Verify failed at address 0000h" blues, try V1.05d. I'll bet it clears things up.
Hope this helps someone.
And thanks for all who contribute here. It's been a great read.
P.S. As predicted (as per all the testimolials here), my laptop serial port doesn't work with the JDM programmer. Voltages are too low. But it works great with one of the servers in my lab (with a "Real" serial interface).
